cheye
6 years agoWhat does .pof file need to be converted to for MAX10 onchip CFM flash programming
Hi, While it is pretty clear that the UFM sections of the onchip Flash memory on MAX10 FPGAs are programmed with .hex files (and as the name suggests the.hex file is just a bunch of hex values), int...
cheye
6 years ago??? This answer is very ambiguous to me..
If I open a .pof or .sof file, they are binaries, no RAW hex formatted data.
In simple words, I want to write to the onchip flash using 2 byte payload SPI transactions...so the SW will read from a file and transmit bytes.
A .pof or .sof file cannot be used?
