17 years agousing stratix II GX transceiver on low data rate..
The specs of startix II GX transceiver development kit says that it can operate from 600Mbps~6Gbps. Does that mean there is no way it can operate on lower speeds like 100Mbps? (Im talking about...
15 years ago --- Quote Start --- Hi, On a further note, if you don't have your data clock available on board then you can use the transmitters at 600Mbps or more by inserting dummy bits. The receiver transmitter must then follow a protocol, either yours or any of available protocols in your tools kaz --- Quote End --- What about the receiver? Is there a way to use the CDR in receiver to recover a clock from 100Mbps bit stream?
