17 years agousing stratix II GX transceiver on low data rate..
The specs of startix II GX transceiver development kit says that it can operate from 600Mbps~6Gbps. Does that mean there is no way it can operate on lower speeds like 100Mbps? (Im talking about...
17 years agoI don't know any details about the board, I see some parts similar to clock drivers on the photo. I assume, you have a manual, it should answer all your questions.
The properties of GX transceivers are discussed in the Stratix II GX manual in detail. I'm in so far familiar to your special question, cause I once considered to use GX receivers on a PLDA board for LVDS input and found, that it can't work.
