17 years agousing stratix II GX transceiver on low data rate..
The specs of startix II GX transceiver development kit says that it can operate from 600Mbps~6Gbps. Does that mean there is no way it can operate on lower speeds like 100Mbps? (Im talking about...
17 years ago --- Quote Start --- Hi, compile your project then open assignment editor, select the required pins and choose the io standard "lvds" instead of default "LVTTL". You will need a 100 Ohm termination resistor between the two signals at the input. If you don't have it on board then choose onchip termination if available in your device- select differential lvds termination in the assignment editor kaz --- Quote End --- Since I am using SMA connectors, it would be difficult to manually connect a 100ohm resistor at the end of the cable. I just hope the board has the 100ohm settings. Still didnt look for it. any other options I can use to implement lvds on this development board?
