Syouf
5 years agoUsing external clock to drive FPGA DE10-Nano
I am working on a project in which I need to use the clock of DE2-115 to drive a DE10-Nano FPGA. I connected the clock signal of the DE2 to one of its GPIO pins, and connected that pin to a ...
JohnT_Altera
5 years agoHi,
Could you check if your board is using 2.5V VCCIO based on JP6 setting? In order to set it to 2.5V, you should short pin 5 and 6.
