13 years agoUsing CML or DQS transceiver pins as LVDS possible in Stratix V DSP Dev Kit?
Hi, Forgive me if the question is basic. I am new to the field of FPGAs. I give a short version of the question. And a long version of the question. For those interested :). Note: Re...
13 years ago --- Quote Start --- AC-coupling seems to be the way to go. I see various strategies. Mostly involving two capacitors. Some indicate a couple of resisters as well. SN65CML100 by TI is also there. --- Quote End --- At 1.6Gbps a couple of 100nF capacitors should be fine. --- Quote Start --- I am guessing the speed limits in such a design would be the limitations of the transceivers on the LVDS side. My application requires upwards of 1Gbps. Preferably close to the LVDS limit of the DE3 (1.6Gbps) --- Quote End --- Yes, the limit will be the LVDS. --- Quote Start --- The hard-IP transceiver block on the Stratix V in basic mode shouldn't be a choking point at these speeds? --- Quote End --- Worst-case, you may find that 1.6Gbps is too slow (but probably not). If that is the case, then configure the transceiver block receivers and CDR PLLs for 2x or 4x oversampling, and just throw-away the 'extra' bits inside the FPGA. You can also use the 'extra' bits for error checking, eg., in 2x over-sampling mode, confirm that each pair of bits is identical. --- Quote Start --- Also, 8/10B introduces a 25% overhead. It should be possible to opt for 64/66B encoding? --- Quote End --- Or PRBS modulation, which introduces no over-head, but does assume a certain level of randomness in your data. Here's a document plus code that generates PRBS patterns: http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial_src.zip --- Quote Start --- Sorry for the petty questions. I can clearly see that I need more practical experience on the FPGA than simply musing over it a-lot and thinking over a bigger design. But I'm learning as it comes. Just don't want to spend time trying to do something impossible :) --- Quote End --- No need to apologize. Asking intelligent questions that show you've thought about the problem will generally result in useful responses :) Cheers, Dave
