13 years agoUsing CML or DQS transceiver pins as LVDS possible in Stratix V DSP Dev Kit?
Hi, Forgive me if the question is basic. I am new to the field of FPGAs. I give a short version of the question. And a long version of the question. For those interested :). Note: Re...
13 years agoThank-you.
AC-coupling seems to be the way to go. I see various strategies. Mostly involving two capacitors. Some indicate a couple of resisters as well. SN65CML100 by TI is also there. I am guessing the speed limits in such a design would be the limitations of the transceivers on the LVDS side. My application requires upwards of 1Gbps. Preferably close to the LVDS limit of the DE3 (1.6Gbps) The hard-IP transceiver block on the Stratix V in basic mode shouldn't be a choking point at these speeds? Also, 8/10B introduces a 25% overhead. It should be possible to opt for 64/66B encoding? Sorry for the petty questions. I can clearly see that I need more practical experience on the FPGA than simply musing over it a-lot and thinking over a bigger design. But I'm learning as it comes. Just don't want to spend time trying to do something impossible :) Thank-you, Zubair
