14 years agoUSB blaster download cable -- Data rate on 10-pin connector
On the USB based Blaster download cable to program the Altera FPGA, we would like to know the Data Rate of signals while programming the FPGA. We are in need of this support information i...
14 years agoExtending the JTAG cable may work for programming if you're in a fairly clean environment and extend it with good quality cable.
If you are using a longer running program such as the Nios II debugger, SystemConsole, nios2-terminal etc then it will be more affected by errors as it's running for longer (hours or minutes as opposed to tens of seconds). You may want to consider extending the USB cable if that's possible as that is differential so more resistant to errors.
