User1571932698773355's avatar
7 years ago
unable to boot my cyclone 5 soc
I used the ghrd to boot my board. I not able to boot. Uboot says bad kernel image.
  • Hello,
    If you use a custom image, you need to take care of several items:
    1- Device tree is up to date.
    2- zImage is compiled successfully without any error.
    3- rbf file is available in the FAT partition.
    4- preloader/uboot should be up-to-date with the FPGA design.
    Please double check the items below, and let me know if none can help.
    Thank you
  • Hello Fjumaah,
    The default sdcard imag is working fine. When I customize my kernel, I cannot boot it. Do you think this might be due to corrupted image?
    Please advice.
  • FawazJ_Altera's avatar
    FawazJ_Altera
    May I know if you are using the default sdcard image file, or you build your custom image? This might be due to either corrupted image, or invalid data read from sdcard.
    Thank you
    FawazJ_Altera
    Thank you
    • thanhtung's avatar
      thanhtung
      Hi all ,
      I have followed this guide to build the image of cyclone5:
      https://rocketboards.org/foswiki/Documentation/CycloneVSoCGSRD
      And i have enough several items as you said. But when i use putty to boot, it's nothing happend. A board (De1-SoC) have loaded sd card and after that nothing happend in screen.
      And i also try using yocto project to build all file and create sd card image with wic file but it's not working too.
      is there someone could help me? Thank all.
