Suhas_1994
5 years agoTransceiver Native PHY Intel Cyclone 10 FPGA IP
I am trying to generate the Transceiver Native PHY using Quartus. The design gets generated successfully. When I try to compile the design, I'm getting the error which is attached below.
CheepinC_altera
5 years agoHi,
Thanks for your update. Would you mind to share a simple test design which could replicate you observation? I would like to further look into it. Thank you.
