Suhas_1994
5 years agoTransceiver Native PHY Intel Cyclone 10 FPGA IP
I am trying to generate the Transceiver Native PHY using Quartus. The design gets generated successfully. When I try to compile the design, I'm getting the error which is attached below.
CheepinC_altera
5 years agoHi,
As I understand it, you have some inquiries related to the Fitter error. As I look at your screenshot, it seems like you are trying to connect the transceiver pins to general purpose IO. For your information, the transceiver pins have dedicated location in a device. I would recommend you to remove all the pin assignment and allow the Fitter to perform autofit. You then refer to the optimal location assigned by Fitter.
Suhas_1994
5 years agoHello,
After generating the design, there are no pin assignments done. When compiled, it still shows the same error as before.
Can you please help me with this??
Thanks in advance.
