BMart12
4 years agoTechnology Map Viewer Post-Fitting signal names
I am using the SignalTap II logic analyzer on Quartus Prime Version : 18.1.1 Build 646 04/11/2019 SJ Standard Edition. I am tracing logic in the Cyclone V SOC to debug a memory-mapped slave...
- 4 years ago
Names can get distorted through the place and route process. The ~ does not necessarily mean anything other than the name of a signal changed or a new internal signal was created through this process. If you know the signals you want to tap from your design itself, use the Signal Tap pre-synthesis Node Finder filter instead of post-fit nodes you find in the Tech Map Viewer.
YEan
Contributor
4 years agoHi there,
Do you have any update on your problem?
Thank you.
Ean
