Technology Map Viewer Post-Fitting signal names
- 4 years ago
Names can get distorted through the place and route process. The ~ does not necessarily mean anything other than the name of a signal changed or a new internal signal was created through this process. If you know the signals you want to tap from your design itself, use the Signal Tap pre-synthesis Node Finder filter instead of post-fit nodes you find in the Tech Map Viewer.
