TCL command to generate MAX10 .pof with 2 sof pages dual compressed images
When I run the command
quartus_cpf -c input_file.sof output_file.pof, an error message popsup saying
"the compiled configuration mode Dual Compressed Internal images must have 2 pages of data.
Correct, but where do I find the correct syntax to execute this.
This cannot be found in ANY documentaiton. None of the tcl scripting manuals for quartus show this information.
When in Quartus doing Convert Programming Files, it is all fine adding a pages of sof, generate the pof and .rpd, .map etc...
But for the MAX10 in this configuration, no documentation!
Please advise
Is there a way to export commands to a file in quartus? So when clicking a button, that I can see the output on a tcl console, pretty much understand what quartus does? It doesn't appear to output anything, just some messages, but not the actual command.
- cheye
got it to work, thanks!
- sstrell
The easiest way to do this would be to set up the pages in the GUI, create a .cof file, and then reference that .cof with the quartus_cpf command.
Usually, any action you perform in the GUI does display the equivalent Tcl command in the Messages window, so I'm surprised it doesn't appear there for this.
#iwork4intel
- cheye
Can you please spefify where in the GUI to setup the pages. Are you referring to convert programming files? I don't see a .cof option here...
And reference .cof how?
No output on the command line
- sstrell
From the File menu in the dialog (not shown in your screenshot): https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd10312014_481.html
#iwork4intel
- cheye
What is my script at the moment only does
execute_flow -compile
quartus_cpf -c file_name.cof doesn't seem to work then
