14 years ago[Target Connection]: Connected system ID hash not found
My quartus project, using Quartus II 11.0 sp1 web edition and Qsys with a DE2-70 board, was made using a working generic project as starting point, made from two terasic example projects, one for con...
14 years agoHi Xkolare,
I just worked through the same problem. In my case it was that my processor was being held in reset. Can you use SignalTap to check that reset_n is driven high? What changes are you making in the Verilog files? Also, you English is quite good :) Regards, Scott
