15 years agoSystem Console Dashboard examples?
I'd like to use the System Console Dashboard to set up some GUIs for demos. The docs I can find are pretty brief (and don't talk much about how to display info received from the development board). ...
15 years agoso I copied the script above into a 2nd script and deleted the 1st 5 commands (so the 2nd script runs only the timechart, assuming the dash is set up). I run the first script - runs ok, then the 2nd script - after a really long time (like a minute) the 2nd chart appeared in its completed form - no luck here I'm afraid.
/j ps - thanks for the pointer to the example - a little more detail than what's in the manual (but no good for solving my issue above)
