15 years agoSystem Console Dashboard examples?
I'd like to use the System Console Dashboard to set up some GUIs for demos. The docs I can find are pretty brief (and don't talk much about how to display info received from the development board). ...
15 years agoHi Wombat - thanks for the reply. The problem I have is this: I wrote a small TCL script like so:
namespace eval dashboard_example { set dash [add_service dashboard dashboard_example "Dashboard Example" "Tools/Example"] dashboard_set_property $dash self developmentMode true dashboard_set_property $dash self visible true dashboard_add $dash time0 timeChart self dashboard_set_property $dash time0 maximumItemCount 10 for {set x 0} {$x < 10} {incr x} { set y [expr $x % 8] dashboard_set_property $dash time0 latest $y after 1000 } } I can run this once, and that first time I run it, it runs properly (you can see it updates 10 times) and looks great. if I run it again, nothing happens for a while, and then the GUI screen updates to the final appearance of the time chart after script completion. If you run it the 2nd time, you'll get the error WARNING: Overwriting /desktop/dashboard_example SEVERE: Cannot register content with passed id. An already registered dockable exists. [id : Dashboard Example] But I get this error with ANY script like this that I run (one that generates dials, tables, etc), and they all run correctly multiple times. If I add a close_service command at the end of the script, I get INFO: The dashboard service does not require or support closing. Close is not performed. Based on these 2 behaviors, Altera Support (10823966) concluded that "you cannot rerun the script without exiting the system-console". I pushed back (answer sounds lame), but it's currently an issue, whether intended or not. HTH - if you have any ideas I'd love to hear them thanks! /j
