14 years agoStratix V GX SI Dev board issue
Hi, I've recently purchased a Stratix V GX Transceiver SI Development Board and I'm having problems getting the Board Test System working. I want to use the SFP loopback feature of the BTS but ...
14 years agoOK, I was miss reading your original post. Sounds like the There is signal on Tx but not on Rx. Sounds like if you have loop back, the GUI should show the Rx...how did you set the serial loop back mode? As far as I recall, you need to set '1' to all the channel(s).
For the CLK GUI, I thought there was a patch on it. ftp://ftp.altera.com/outgoing/devkit/patch You may want to give them a try.
