14 years agoStratix V GX SI Dev board issue
Hi, I've recently purchased a Stratix V GX Transceiver SI Development Board and I'm having problems getting the Board Test System working. I want to use the SFP loopback feature of the BTS but ...
14 years agoCouple of things to check...
Is design loaded correctly? you may want to check LEDs are blinking. Is all dipsw(es) set correctly? Lastly, is clk(s) set correctly? You can(need to) set Si570.
