14 years agoStratix V GX SI Dev board issue
Hi, I've recently purchased a Stratix V GX Transceiver SI Development Board and I'm having problems getting the Board Test System working. I want to use the SFP loopback feature of the BTS but ...
14 years agoHave you tried hitting the clear button?
Also, try using serial loop back just in case. To do that, go to PMA setting and check all the serial-loopback(s) so you should be able to see the RX data.
