13 years agoStratix V DSP Kit Transcievers
Hi, I was looking at the schematic and the reference manual for the Stratix V DSP development kit http://www.altera.com/products/devkits/altera/kit-stratix-v-dsp.html The transceivers...
13 years ago --- Quote Start --- What I don't understand is why there are single-ended clock input/outputs on the banks of the port for transceivers. Am I missing something? --- Quote End --- The HSMC standard does not define clocks for the transceivers. The connector defines clocks, but says nothing about what they need to go to. Ideally there would be a clock going to a transceiver block REFCLK input, but that is not a requirement. --- Quote Start --- Can transceivers function easily without a differential frame clock? --- Quote End --- The term "frame clock" is terminology used to describe a lower-speed clock that is synchronous, i.e., has some form of time alignment, with LVDS data. A transceiver has a REFCLK, which is a reference clock with a relationship to the bit-rate of the transceiver data, but no requirements on a phase relationship (other than being low jitter). --- Quote Start --- I have a differential frame clock I'd like to use to simplify the of deciphering the data-stream. --- Quote End --- That'll never happen. The receiver CDRs lock their own PLLs. You cannot recover multi-bit-width data unless the data stream itself has some form of synchronizing code embedded within it. --- Quote Start --- But I can't connect it to the Transceiver PHY mega-function's CDR reference clock. And connecting the single-ended clock to the CDR reference clock of the mega-function isn't working either. Any ideas as to where I am going wrong? --- Quote End --- Check out the example designs that come with the kit. Perhaps they have a clocking scheme example you can re-use. What are you trying to do? Cheers, Dave
