11 years agoStratix IV Dev Board with Nios II Ethernet Standard Design: No PHY connected
I have an Altera Stratix IV 4sgx230 Development Board and using the NIOS II Ethernet Standard Design Example. I have found an issue where the PHY communication fails with the error “No PHY connected”...
10 years agoI am using the exact same board and configuration with Quartus II v15.0. As you said, driver for TSE is NOT included in the BSP. I was suggested in other forum (http://www.alteraforum.com/forum/showthread.php?t=50537)to change to QII v12.0 for things to work.
This is ridiculous as my company has license for v15.0 and want to use other new features of QII v15.0. I get the following Nios II console message: InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prepped 0 interfaces, initializing... inet setup error: unable to find any working interfaces panic: IP dtrap - needs breakpoint
