Hans_1st
4 years agoStratix 10 SX FPGA Level 4 Slave Peripheral Bus Control Configuration
Hello All,
Thanks for reading my problem!
I am working on controlling UART1 in Intel Stratix 10 SX SoC Development Kit output something. I use SignalTap II to simulate and the result is that th...
EricMunYew_C_Intel
4 years agoYou can modify the security control register by referring to below.
Hans_1st
4 years agoThanks for replying!
I checked this web and I had some questions want to ask:
(1) Is this Appendix only based on using ATF (Arm Trusted Firmware) as the Secure Monitor or not? Because EL3 is only generated by building Arm Trusted Firmware.
(2) If I want to use U-Boot as the Secure Monitor (non-ATF way) to control UART1 on L4 Slave Peripheral Bus, I know I can manage/configure secure L3 or L4 registers in "u-boot.scr" file. So how many and what kind of registers should I manage/configure to achieve my goal?
