Stratix-10 SoC JTAG ID Error Code
- 5 years ago
Yes, you need to in order to program the board correctly.
We do not have the image file for H-tile board, what you have is the H-tile version of S10 SoC, you can create your own image by getting first the GHRD from 20.4 SoC EDS, in the installation files inside "example/hardware" the folder name will have htile at the end.
Then you may follow the steps below to create the image, most of the steps are the same, but some may need to readjust accordingly for example the creation of the jic file:
- ml75 years ago
Thank you for your response. I am now able to generate the GHRD using the makefile with the QUARTUS_DEVICE ?= 1SX280HU1F50E2VG. The issue now comes down to the JTAG ID that lists the part as the following: C322D0DD 1SX280HH1(.|S3)/1SX280HH2/..
So does the flash_loader need to be set to 1sx280hh1? Does the part ID also have to be set to HH1 in the Quartus project?
- EBERLAZARE_I_Intel5 years ago
