Stratix 10 SOC Development Kit example design qts_fmca_Q18.0.1_B261
Have you you tried opening the original and entire project file, ".qpf", then try recompiling it after opening the .qpf file.
- MohanY5 years ago
Yes. The following are the errors that I get with Quartus Prime Pro 18.0.1 Build 261
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_xcvr_user_tx_fifo_converter_0.ip.
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_freq_counter_0.ip.
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_xcvr_tx_rx_clkout2_converter_0.ip.
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_mm_bridge_0.ip.
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_data_pattern_generator_0.ip.
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_xcvr_user_rx_fifo_converter_0.ip.
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_rx_fifo.ip.
Error: Error opening C:/p/psg/board/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/ip/xcvr_test_system/xcvr_test_system_data_pattern_checker_0.ip.
Error: Error opening C:/nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/xcvr_test_system.qsys.
Error: Error opening C:/nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/cmos_test_system.qsys.
Error: Error opening C:/nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/fmc_xcvr_test_gx_2.qsys.
Error: Error opening C:/nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/fmc_cmos_system.qsys.
Error: Error opening C:/nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/fmc_xcvr_test_gx.qsys.
Error: Error opening C:/nfs/site/disks/psg_board_1/nwang/Stratix10_soc/reference_designs/RevA1_SX/Q18.0.1_B261_LTPRD/qts_fmca_Q18.0.1_B261/fmc_xcvr_test_gxt.qsys.
Error: Quartus Prime IP Generation Tool was unsuccessful. 15 errors, 0 warnings
Error: Peak virtual memory: 4717 megabytes
Error: Processing ended: Tue Jul 13 15:18:36 2021
Error: Elapsed time: 00:00:29
Error: Total CPU time (on all processors): 00:00:35
Error(293001): Quartus Prime Full Compilation was unsuccessful. 17 errors, 0 warnings- EBERLAZARE_I_Intel5 years ago
Do you have a valid Quartus Pro license? Did you try to compile the GHRD instead if that would compiled succesfully.
