MohanY
5 years agoStratix 10 SOC Development Kit example design qts_fmca_Q18.0.1_B261 not compiling
I am trying to compile an example design for the Stratix 10 SOC Development Kit.
Under Development Kit Documentation , I downloaded and installed L-Tile Production (18.0.1 or higher)
Tried the f...
AR_A_Intel
5 years agoHi
Thanks for update and apologies for the delay as I was out of office recently. As per my understanding, dev kit reference design is meant to be used with the specific Quartus version only, we don’t support reference design upgrade using Quartus version. The recommendation is to stick with the same Quartus version.
Also, the dev kit reference design is meant mainly for BTS (board test system) testing only and if you are interested to learn about some specific IP, then you can refer back to the IP solution example design. Thanks
