BigHandsomeBee
5 years agoStratix 10 DX Development Kit Example Design Not Working
I'm trying to compile the example design provided for Stratix 10 DX development kit, but the compilation failed.
However, the provided example sof file is working.
Below are the steps I have done...
- 5 years ago
May I know if you have connected the XCVR IP to the Golden design? The reason is that the XCVR pin will not be assigned to pin connection if it is not connected to the XCVR IP. So I would recommend you to comment out the XVCR pin for PCIe or UPI interface if you are not using it.
JohnT_Altera
5 years agoAttach is the updated top level file which I commented out the XCVR ports.
