Stratix 10- L tile SoC Dev kit: SignalTap hangs JTAG chain
- 6 years ago
I contacted local support team(Cytech) in Bangalore and got couple of suggestions.
As per the suggestions, I revisited the scenario & the problem was some java task related to JTAG is running in the background. I manually closed the task using Task Manager & relaunched Quartus & signaltap. Now everything looks fine.
With Regards,
HPB
Yes, I can program the sof (different sof files one after the other )to dev kit many times if I am not opening signaltap file & scan the chain.
However, If I open signatap & click scanchain, the JTAG chain gets hanged. After that I cant program any sof file.
If I power cycle the board, then I can program the sof again.
With regards,
HPB
With Regards,
HPB
