14 years agoStatrix IV clock pins assigment (Terasic DE4 dev kit)
Dear community members, We have a little doubt releated to DE4 dev kit by Terasic. We are developing a simple fan controller. Initially, we have used DE4 System Builder projects as refere...
14 years ago --- Quote Start --- But I believe that you're right. --- Quote End --- Don't just guess, use the tools to know! The Quartus II tool generates a file; Fitter->Pin Out Look at that file. Also look at the setting for unused pins; Assignments->Device, Device and Pin Options, Unused Pins. The default for Stratix IV is "As input tri-stated with weak pull-up". However, for older devices this used to be "As output driving ground". So if you inherit an older project and blindly assume that unused pins are tri-stated by default, you could damage that board. So, now you know :) Cheers, Dave
