15 years agoSimple game using Max II starter kit
Hi! I really need help to the expert since I am not really familiar with Max II and verilog programming. This would be our final project for this semester. The game is called "catch the L....
15 years agoThank for your immediate reply sir.. I do have "ModelSIn ALtera Starter Edition v6.4a" installed.
I'm going to test it now. I'll just have test it now. New environment. :) I will post later result. :) EDIT: HELLO ,SIR' I'm having a trouble running your sample code in ModelSim Altera. here is the logs.# Reading C:/altera/90/modelsim_ase/tcl/vsim/pref.tcl
cd c:/temp# reading modelsim.ini
dir# Volume in drive C is JLwinXP# Volume Serial Number is 6435-3543# # Directory of C:\temp# # 09/11/2011 07:01 PM <DIR> .# 09/11/2011 07:01 PM <DIR> ..# 09/11/2011 06:52 PM 4,119 catch_mouse.sv# 09/11/2011 01:55 PM 0 hex_display.sv# 09/11/2011 01:56 PM 0 hex_display_tb.sv# 09/11/2011 06:57 PM 6,267 modelsim.ini# 09/11/2011 07:01 PM <DIR> mwork# 4 File(s) 10,386 bytes# 3 Dir(s) 50,575,568,896 bytes free
vlib mwork
vmap work mwork# Modifying modelsim.ini
vlog -sv hex_display.sv# Model Technology ModelSim ALTERA vlog 6.4a Compiler 2008.08 Oct 22 2008
vlog -sv hex_display_tb.sv# Model Technology ModelSim ALTERA vlog 6.4a Compiler 2008.08 Oct 22 2008
vsim -novopt hex_display_tb# vsim -novopt hex_display_tb # ** Error: (vsim-3170) Could not find 'C:\temp\mwork.hex_display_tb'.# Error loading design
vsim -novopt hex_display_tb.sv# OpenFile hex_display_tb.sv
add wave *
run -a# No Design Loaded!
