15 years agoSimple game using Max II starter kit
Hi! I really need help to the expert since I am not really familiar with Max II and verilog programming. This would be our final project for this semester. The game is called "catch the L....
15 years agothis is the running code: :D
module segmentTrial(clk,tick,seg,seg_sel,mouse,button1,button2,button3,button4);
input clk,button1,button2,button3,button4;
output seg;
output seg_sel;
output tick;
output mouse;
reg tick;
reg mouse;
reg seg;
reg seg_sel;
integer i,r,minute1,second,minute2,hour1,hour2,counter,mouseCom,catch,Buttontiming;
/* 7 segement patern */
parameter one = 8'b100_1111_1; //159
parameter zero = 8'b000_0001_1; // 3
parameter two =8'b001_0010_1; // 37
parameter three=8'b000_0110_1; // 13
parameter four =8'b100_1100_1; //153
parameter five =8'b010_0100_1; // 73
parameter six =8'b010_0000_1; // 65
parameter seven=8'b000_1111_1; // 31
parameter eight=8'b000_0000_1; // 1
parameter nine =8'b000_0100_1; // 9
parameter blank=8'b111_1111_1; //255 */
/* End of 7 segement patern */
/* mouse pattern ;) */
parameter com0 =8'b010_0000_1;
parameter com1 =8'b000_1000_0;
parameter com2 =8'b001_0000_0;
parameter com3 =8'b010_0000_0;
parameter com4 =8'b100_000_0;
parameter com5 =8'b001_0010_0;
parameter com6 =8'b00_0100_1;
parameter com7 =8'b100_0100_1;
parameter com8 =8'b100_0100_0;
parameter off = 8'b000_0000_0;
/* End of mouse pattern ;) */
initial minute2 = 0;
initial minute1 = 0;
initial hour2 = 5;
initial hour1 = 9;
initial counter = 60;
initial seg_sel = 4'b0001; //intialize seleector digit 1
initial mouse = ~off;
/* 1 minute countdown counter */
always@(posedge clk)
begin
if(i==16000000) //1Hz
begin
i=1;
counter = counter-1'b1;
if(counter == 0) //reset everything after count
begin
mouse = ~off;
hour1 = 0;
hour2 = 0;
end
if(counter != 0); //to prevent displaying something after count zero
begin
hour1 = counter % 10;
end
if(counter == 49 ||counter == 39 || counter == 29 || counter == 19 || counter == 9)
begin
hour2 = hour2-1'b1;
end
end
else
begin
i=i+1'b1; //increament i
end
if(Buttontiming==4000000) //button detection delay
begin
mouseCom = hour1;
Buttontiming = 1;
if(mouseCom==3)
begin
mouse = ~com1;
if(button1==0)
begin
minute1 = minute1+1'b1;
end
end
else if(mouseCom == 1)
begin
mouse = ~com2;
if(button2 == 0)
begin
end
end
else if(mouseCom == 6)
begin
mouse = ~com6;
if(button4 == 0 && button1 == 0)
begin
minute1 = minute1+2;
end
else if(button4 == 0 || button1 == 0)
begin
end
end
else if(mouseCom == 8)
begin
mouse = ~com4;
if(button3 == 0)
begin
end
end
else if(minute1 == 10)
begin
minute1 = 0;
minute2 = minute2+1'b1;
end
else
begin
mouse = ~off;
end
end
else
begin
Buttontiming=Buttontiming+1'b1;
end
end
/* End of 1 minute countdown counter */
/* Segment Selector */
begin
if(r==800)
begin
tick=~tick;
r=1;
end
else
begin
r=r+1'b1;
end
end
/* End of Segment Selector */
/* 7 segment Display Library */
always@(posedge tick)
begin
seg_sel={seg_sel,seg_sel};
if(seg_sel==4'b1000)
begin
case(hour2) 0:seg=zero; 1:seg=one; 2:seg=two; 3:seg=three; 4:seg=four;
5:seg=five; 6:seg=six; 7:seg=seven; 8:seg=eight; 9:seg=nine;
endcase
end
else if(seg_sel==4'b0100)
begin
case(hour1) 0:seg=zero; 1:seg=one; 2:seg=two; 3:seg=three; 4:seg=four;
endcase
end
else if(seg_sel==4'b0010)
begin
case(minute2) 0:seg=zero; 1:seg=one; 2:seg=two; 3:seg=three; 4:seg=four;
endcase
end
else if(seg_sel==4'b0001)
begin
case(minute1) 0:seg=zero; 1:seg=one; 2:seg=two; 3:seg=three; 4:seg=four;
endcase
end
end
/* End of 7 segment Display Library*/
endmodule
sir, how do i improve this something like adding a several combination of lighting the bulb? let's say 100 combinations or more? how am i gonna do this in an array form or in case?
thank you! :)
