SignalTap Logic Analyzer rapid compile failure
- 4 years ago
The screenshots indicate a Quartus crash, not errors with the compile like you state. Easiest thing to do is delete the db and incremental_db folders and recompile from scratch.
If you're saying that even after this, with the current .stp file that Quartus is still crashing when the .stp is enabled, it's possible that your .stp file is corrupt. Create a new one and match the settings you have.
- BMart124 years ago
Thank you. Deleting the db and incremental_db folders and recompiling fixed the problem.
