BMart12
4 years agoSignalTap Logic Analyzer rapid compile failure
I am using the Signal Tap II logic analyzer on Quartus Prime Version : 18.1.1 Build 646 04/11/2019 SJ Standard Edition. I have been tracing logic in the Cyclone V SOC for over a month. Sin...
- 4 years ago
The screenshots indicate a Quartus crash, not errors with the compile like you state. Easiest thing to do is delete the db and incremental_db folders and recompile from scratch.
If you're saying that even after this, with the current .stp file that Quartus is still crashing when the .stp is enabled, it's possible that your .stp file is corrupt. Create a new one and match the settings you have.
ShengN_altera
4 years agoHi BMart12,
I think you can enable back Signal Tap and try compiling again with newer version Quartus.
See whether the error still persist?
Sheng
