GTown
7 years agoSetting 100 MHz on Stratix IV GX
I have a working design using the usual 50MHz clock which I've had running successfully on a much smaller FPGA from Xlinix at 100 MHz. I've googled and scoured the forum, but can't quite find a solut...
Abe
7 years agoHi,
When using designs with clocks in them, you have two steps involved:
- Assign the clock to respective clock pin via Pin Planner / Assignment editor. If the clock is a single-ended one , you can connect it to any of the CLKn/CLKp pins on the device.
- Add a SDC (Synopsys Design Constraints) file to the project which will mention the clocks , delays, etc. In the SDC you will mention the clock period aka Frequency of operation and have the tool look for the associated clock in the design and apply to it.
- Also mention the input and output delays, false-paths and multi-cycle paths if any.
all of these put together will ensure that your design works as it should for that required frequency/timing requirements.
Examples of SDC file:
# Time Information
set_time_format -unit ns -decimal_places 3
# Create Clock
create_clock -name {altera_reserved_tck} -period 33.333 -waveform { 0.000 16.666 } [get_ports {altera_reserved_tck}]
create_clock -name {sys_clk} -period 20.000 -waveform { 0.000 10.000 } [get_ports {FPGA_Clk_50Mhz}]
create_clock -name {vClk} -period 20.000 -waveform { 0.000 10.000 }
# Clock Uncertainity
derive_clock_uncertainty
# Input Delay
set_input_delay -clock { vClk } 0.0 [get_ports {FPGA_Clk_50Mhz FPGA_reset}]
set_input_delay -clock { vClk } 0.0 [get_ports {altera_reserved_tck altera_reserved_tdi altera_reserved_tms}]
# Output Delay
set_output_delay -clock { vClk } 0.0 [get_ports timer_out]
set_output_delay -clock { vClk } 0.0 [get_ports altera_reserved_tdo]
