9 years agoSDRAM Usage for the DE1-Soc Board
Hi guys, I want to save data in the SDRAM and afterwards to read out the data from the SDRAM. For my project, I used the Qsys and implemented the components afterwards in my VHDL code. Wh...
9 years ago --- Quote Start --- Hello Christoph, SDRAM is a complex chip that requires special logic to operate. It needs an external refresh mechanism to keep it going, I think this aspect is not in your code. Best Regards, Johi. --- Quote End --- Hi John, thank you for your information. I added you the latest code below. process(CLK143) begin if rising_edge(CLK143) then --write process --case BUFF_CTRL is --when st0=>------------write image to SDRAM --if (SDRAM_WAIT='0')then SDRAM_WE_N<='0'; SDRAM_RE_N<='1'; --SDRAM_WRITEDATA<="1010101010101010"; DRAM_DQ(15) <= '0'; DRAM_DQ(14) <= '0'; DRAM_DQ(13 downto 0) <= ADC_DB(13 downto 0); SDRAM_WRITEDATA<=DRAM_DQ; SDRAM_ADDR<=std_logic_vector(unsigned(SDRAM_ADDR)+1); --end if; --when st1=>-----------write from SDRAM to BUFFER SDRAM_WE_N<='1'; --RAMWE1<=SDRAM_RDVAL; --SDRAM_RDVAL<='1'; RAMWE1<='1'; SDRAM_RE_N<='0'; SDRAM_WAIT<='0'; SDRAM_ADDR<=std_logic_vector(unsigned(SDRAM_ADDR)+1); RAMIN1<=SDRAM_READDATA(15 downto 0); --end case; end if; end process; I am able to write the data but when I read it, I got the wrong value. Do I have to implement the whole FSM to use the SDRAM properly? Thanks, Chris
