10 years agoSDRAM + I2C (nios II?) + VHDL + VGA= QSYS? Connecting VHDL with Qsys (DE0-Nano)
Hello, I need to control my camera OV7670 with I2C protocol (so it's best to use nios II i think) and i need to interface it with VGA and some image processing VHDL files, which will be fetching i...
10 years agoI have already achieved 160x120 image, but whole image is quite "yellow" (i will place video here but tomorrow, when ill get better light from sun rather than bulb). Also i had to change some registers, IMO Hamster made few mistakes:
- check register 0x3E with value 0x19 - PCLK scaling comment says that PCLK = 4, its not true, PCLK is 2 with this setup (check datasheet); - register 0x73 is set to value 0xF1 - ive changed it to 0x01 (4 oldest bits are reserved and initially set to 0) - he set lowest set bit correctly for PCLK = 2; - register 0xA2 is set to value 0x02 - ive changed it to 0x01 (0x02 stands for PCLK divided by 4 - checked with oscilloscope); - also commented all other registers setup from 0xA2 (when x"14"-...-x"36") - better quality in my opinion Two funny things: - cant find information about register 0xA2 in datasheet (9F-AB Histogram-based AEC/AGC ControlXX–Histogram-based AEC/AGC Control); - Hamster I2C reset command seems not working - i mean when i reprogram fpga when it has already some VHDL description in it camera bahaves different than if i upload VHDL design after powering up the de0 nano device - this may be cause of all of my problems (with colors in example and the image quality is quite bad), thats why i wanted to use uC for I2C setup. As i've said, ill upload video of my results tomoroww and also i can upload project if You want, but ill be working on interfacing design with SDRAM to get better resolution and quality anyway . 1 more thing - im using 5 bit DAC for each color, so im setting 3 oldest R, 3 oldest G and 2 oldest B (same 8bit setup from hamsterworks) - rest of bits are set to "0":vga_red <= frame_pixel(7 downto 5) & "00";
vga_green <= frame_pixel(4 downto 2) & "00";
vga_blue <= frame_pixel(1 downto 0) & "000"; edit and here's video showing results of above operations [video=youtube;F1W-AwpiE1M]https://www.youtube.com/watch?v=F1W-AwpiE1M[/video] About visible colorful noise - i think its wire's fault, it behaves better when i hold cables connecting ov7670 (PCLK = 12,5 MHz) or when i use lower PCLK (PCLK = 4 -> PCLK = 6,25 MHz) - in the other situation i receive like 4 frames divided on LCD showing same scenario with some shift - im thinking about changing some clocks in design mayby it will help, anyway my goal now as i mentioned many times is to get better resolution by adding SDRAM (also better colors). Im suprised that quality of shown video is bad if it is about colors, i mean RGB 3-3-2 gives about 2^3*2^3*2^2 = 256 color combinations and presented images are very monochrome (depending of light).
