SD card and eMMC Transceivers for 1.8V
I see, well since the HPS I/O use a fixed voltage level and cannot be changed dynamically, transceivers are required to support level-shifting and isolation for cards that can operate at 1.8 V.
The SD/MMC cards support various operating voltages, for example 1.8V and 3.0V. If you have a card which is at 1.8V and you eject it and replace it with another card, which is 3.0V, then voltage switching is required. Many SD cards have an option to signal at 1.8 or 3.0 V, however the initial power-up voltage requirement is 3.0V. To support these different voltage requirements, external transceivers are needed.
More information here on page 1721 (Flow Diagram).
Regards.
So for eMMC this trancievers are not required right ? because this voltage doesn't change as SD card . So 1.8V emmc device should work .
- EBERLAZARE_I_Intel7 years ago
If the operating voltages are both 1.8V as mentioned, external transceiver are not required.
Regards.
