DZhu1New Contributor6 years agoS10器件是否可以屏蔽Smart VID功能?如何屏蔽 由于电源设计错误,目前调试,核电压只能用稳压电源进行供电,但是因为烧录sof文件时,FPGA会通过PMBUS与电源进行交互,交互如果失败,就会导致sof文件无法烧录?这是否有办法可以解决暂时的调试问题?谢谢
DZhu1New Contributor6 years agoHi How to cut the PM bus communication.The device uses PM bus by default.thanks
Recent DiscussionsBoard Test System Download Package – Stratix 10 TX Signal Integrity Development KitDE2-115 Nios VGA demoAXE5-Falcon using the J8/J9 MIPI connectors?SolvedInstaller Package for DK-DEV-10AX115S-BAgilex 5 E-Series 065B Premium Dev Kit - is FPGA_3V3_SDA/SCL driven by an HPS I2C controller?
