Stratix 10 SoC Dev Kit - L-tile - FPGA-DDR4 (SODIMM ) Example design
Anybody has the FPGA-DDR4 (16GB) design for Stratix 10 SoC dev kit?
With regards,
HPB
You need to download package installer from below page, and then you can find the design locates in download zip file. It locates in examples/sodimm_ddr4 folder.
- HBhat26 years ago
Contributor
Yes, I have downloaded the package & tried to create the project as mentioned in the readme file.
I ran the below command in command prompt & I am getting the error message while creating the project
quartus_sh -t make_qii_design.tcl
Error (23035): Tcl error: child process exited abnormally
while executing
"exec -ignorestderr $qsys_generate_exe_path $qsys_file --pro --synthesis --family=$family --part=$device >>& ip_generate.out"
(file "make_qii_design.tcl" line 98)
while executing
Error (23031): Evaluation of Tcl script make_qii_design.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 4871 megabytes
Error: Processing ended: Tue Aug 25 09:59:37 2020
Error: Elapsed time: 00:00:23------------------------------------------------------------------------------------------
I am using Quartus pro 18.1 & licensed for stratix 10 device.
With regards,
HPB
- ybin6 years ago
I can reproduce this error. You can refer to below link to generate a example design based on the emif component in ed_synth.qsys locate in emif_s10_0_example_design folder.
https://www.intel.cn/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20120.pdf
- HBhat26 years ago
Contributor
Thanks for reproducing the problem & it will be great if Intel supports how to solve this.
Regarding the example design, I have done something similar as mentioned in the "External Memory Interfaces Intel® Stratix® 10 FPGA IP Design Example User Guide". However, I will once again correlate between this document & my design & keep you posted.
Wit Regards,
HPB
