matif
7 years agoPutty Terminal Output not correct
Hi, I wrote this code so that I could display the number on putty which is being represented by LEDS on my Cyclone V board. The leds on board are working perfectly fine. But the output on my putty t...
SreekumarR_G_Intel
7 years agoCan you look at the baud rate setting ? May I know which FPGA you are using in your design ? Also can share the FPGA design file ?
Thank you,
Sree
