SATC
6 years agoProgramming the Image Core: Error - quartus_cvp is not recognized as an internal command.
I'm trying to connect the Intel Cyclone 10 GX device to PCIe. When I execute the command described in the Intel manual: quartus_cvp --vid=<Vendor ID> --did=<Device ID> xxx.core.rbf The terminal pr...
- 6 years ago
After further checking, it looks like quartus_cvp is no longer supported. Sorry for the inconvenience.
Could you try to restart your PC again and try to performed "cp <filename>.core.rbf /dev/altera_cvp"? I suspect that the PCIe link might be in used which cause the issue.
JohnT_Altera
6 years agoHi,
Could you try to install the Quartus CvP from the Quartus installation to see if you are facing any issue?
nstalling Jungo WinDriver in Linux Systems
- Navigate to <Quartus Prime installation path>/quartus/drivers/wdrvr/linux<32 or 64> 2.
- Run the following commands:
- ./configure --disable-usb-support
- make
- su
- make install
- You can change the permissions for the device file. For example, chmod 666 /dev/windrvr6.
- For 64-bit Linux systems, set the Quartus_64BIT environment variable before you run quartus_cvp using the following command:
- export QUARTUS_64BIT=1
- You can use the quartus_cvp command to download *core .rbf files to your FPGA. The following table lists the quartus_cvp commands for all modes
