SATC
6 years agoProgramming the Image Core: Error - quartus_cvp is not recognized as an internal command.
I'm trying to connect the Intel Cyclone 10 GX device to PCIe. When I execute the command described in the Intel manual: quartus_cvp --vid=<Vendor ID> --did=<Device ID> xxx.core.rbf The terminal pr...
- 6 years ago
After further checking, it looks like quartus_cvp is no longer supported. Sorry for the inconvenience.
Could you try to restart your PC again and try to performed "cp <filename>.core.rbf /dev/altera_cvp"? I suspect that the PCIe link might be in used which cause the issue.
JohnT_Altera
6 years agoHi,
Since you are using the open source CvP driver, the instruction to performed it will be "cp <filename>.core.rbf /dev/altera_cvp". Please refer to README of the custom CvP driver source code folder.
