Programming the Image Core: Error - quartus_cvp is not recognized as an internal command.
- 6 years ago
After further checking, it looks like quartus_cvp is no longer supported. Sorry for the inconvenience.
Could you try to restart your PC again and try to performed "cp <filename>.core.rbf /dev/altera_cvp"? I suspect that the PCIe link might be in used which cause the issue.
Hi John, thank you for your attention,
Actually, I used the sample Linux driver source code provided by Intel to program a custom CvP driver. After follow the installation instruction of https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/devices/cfg-index/cfg-via-protocol.html, I tried execute the command quartus_cvp --vid=<Vendor ID> --did=<Device ID> xxx.core.rbf to to have access to the data passed to the pci through the board
