SATC
6 years agoProgramming the Image Core: Error - quartus_cvp is not recognized as an internal command.
I'm trying to connect the Intel Cyclone 10 GX device to PCIe. When I execute the command described in the Intel manual: quartus_cvp --vid=<Vendor ID> --did=<Device ID> xxx.core.rbf The terminal pr...
- 6 years ago
After further checking, it looks like quartus_cvp is no longer supported. Sorry for the inconvenience.
Could you try to restart your PC again and try to performed "cp <filename>.core.rbf /dev/altera_cvp"? I suspect that the PCIe link might be in used which cause the issue.
JohnT_Altera
6 years agoHi,
Do you install Quartus in your system? May I know if you have setup your system environment? If yes, could you share with me your system environment?
