10 years agoProblem Implementing clock in Cyclone II (Altera-DE2)
Hello, I want to generate a clock with 50% duty cycle, but the frequency must be 9999 Hz <= f < 10000 Hz. I tried implementing with counter division and multiplication, but can't seem to find the ...
10 years agoHi,
because it is Christmas. A simple clock divider you simply need to change the divider variable to the correct number. It depends from your ref clock and what clock you want. Alternatively, you can use a PLL using the megawizzard.
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.NUMERIC_STD.ALL;
ENTITY counter IS
PORT(
CLK : IN STD_LOGIC;
CLR : IN STD_LOGIC;
DIV_CLK : OUT STD_LOGIC
END ENTITY counter;
ARCHITECTURE logic OF counter IS
BEGIN
PROCESS(CLK, CLR)
VARIABLE DIVIDER : UNSIGNED(23 DOWNTO 0) := (OTHERS => '0');
BEGIN
IF CLR = '0' THEN
DIVIDER := (OTHERS => '0');
ELSIF rising_edge(CLK) THEN
DIVIDER := DIVIDER + 1;
IF DIVIDER = "011111111101001000000000" THEN
DIV_CLK <= '1';
ELSE
DIV_CLK <= '0';
END IF;
END IF;
END PROCESS;
END ARCHITECTURE logic;
