preloader generation for modified Qsys?
I am currently doing a project using altera De0 nano SOC board. I have modified the GHRD project Qsys according to my requirement. I need to route HPS I2C-2 peripherals to FPGA side to control an external peripheral. I have modified the dtb and rbf files and loaded in the SD card but i am facing some problems.
1. I guess i need to generate the preloader again for the modified qsys. I am not getting how to do that. Please help me in that.
2. What other files i need to update in my SD card for the modified design to make it work properly.
- AnandRaj_S_Intel
After modifying the GHRD, Compile Quartus Project
- Check QSys system
- Generate SOPCinfo file
- generates Handoff folder
Steps
- Open SoC EDS Command shell. $ bsp-editor&
- From BSP Editor : File > New BSP File > [Generated HPS Folder: hps_isw_handoff / demo_hps_0]
- Choose BOOT_FROM_SDMMC and enable the FAT_SUPPORT because BootLoader(aka U-Boot) has particular filename on the FAT partition of the SD card.
- Click “Generate” to generate Pre-Loader source files
- At this stage, BSP Editor generated a “Makefile” script as well as “software > generated” folder that has the specific customization for a particular board.
- In order to make the Pre-Loader, change your directory to “<project>/software/spl_bsp” and type $ make in the SoC EDS command shell.
- After Pre-Loader is generated, type “$ make uboot” in the SoC EDS command shell to generate the U-Boot files.
We have to update preloader and u-boot i.e Partition 1 & Partition 2 of sd card
- Insert the SD card into your PC’s SD card slot.
- Update Pre-Loader with new version(the generated files) using below command-p (point to .bin file..) , -a (action), -d (drive), $ alt-boot-disk-util.exe –p preloader-mkpimage.bin –a write –d i
- copy U-Boot image into SD card using normal linux file copy command. $ cp uboot-socfpga/u-boot.img /cygdrive/i
- sync to safely pull out the SD card from PC’s SD slot. $ sync
Anand Raj Shankar
- sjain14
Hi Anand,
Thanks for the solution. I have followed the steps and now my I2C-2 controller is active but still after some time it gives an error "i2c_designware ffc06000.i2c: controller timed out" I am not able to find out what is causing this error. Is there anything i need to add in my device tree to rectify this problem?
