SDe_J's avatar
SDe_J
7 years ago
Power up the VCCR_GXB and VCCH_GXB rails of stratix 10 L-tile
I am trying to program a stratix 10 L-tile dev kit using Quartus 18.1.
I can compile the project, when when I try to program the board, It gets to 13%, then fails.
I found this page: https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/component/2019/error---device-has-stopped-receiving-configuration-data-error-me.html
Which seems to be the issue I'm having, but I'm not sure how to actually apply the assignments from the workaround.
Thanks for the assistance.
  • Rahul_S_Intel1's avatar
    Rahul_S_Intel1
    As a first debugg step can you reduce the speed of the Jtag clock
  • Shark121's avatar
    Shark121
    I met the same problem with you, have you solved with it? Thank you!
