10 years agoPLL on Altera DE3 Development Board doenst work
Hello everyone, im using the developement board altera DE3 (Stratix III , EP3SL150f1152C2N) for my master thesis. Im trying to use a PLL to get a higher clock. Therefor im using the internal 50...
10 years agoIt appears the physical PLL signal are not properly connected inside your PLL component (ie. clk => open).
I don't understand why you used Qsys to generate the PLL component which is supposed to be controlled like an Avalon MM slave: from the code you posted it seems your design doesn't rely on an Avalon infrastructure.
