15 years agopin assignment
hi: In order to draw a PCB which contains BGA chip (FPGA)conveniently,I want to assigned pin manually in the quartusII,so I can check the correctness of my assignment thougth quartusII compilati...
15 years ago --- Quote Start --- hi: In order to draw a PCB which contains BGA chip (FPGA)conveniently,I want to assigned pin manually in the quartusII,so I can check the correctness of my assignment thougth quartusII compilation. after compilation,there is no error about assignment ,but there is a critical warning,that is :"timing requirments for slow model timing analysis were not met ". I want to know if or not the problem of timing waring need to overlook ? and there is another questions: Besides pin assignment maunally,is there any better way to assign pins,expecialy for BGA packaging? --- Quote End --- Hi, the warning means that your design did not run with the required clock speed. If you did not define a clock requirement Quartus ( TimeQuest) assumes a clock frequency of 1 GHz, which is normally not a realistic requirement. Kind regards GPK
