PCIE hard ip issue, when i try to integrate two PCIE hard IP's ,than synthesis is being failed.( family Cyclone V , gx )
- Pa1_bhandari7 years ago
Dear Nathan,
Thank you so much for your valuable time and links, i will check them, if i get doubt's i will let you know.
Best Regard's
Pavan
@[email protected] @[email protected]
Hi Nathan,
As i have assigned top(EP1) with x1 lane and bottom(EP0) with x2 lane.
currently there is no design , only top file with I/O's.
Bank Number | Location |
EP1
GXB_L2 GXB_TX_L6n P3 PCIE _EP1_TX[0]_N
GXB_L2 GXB_TX_L6p P4 PCIE _EP1_TX[0]_P
GXB_L2 GXB_Rx_L6n R1 PCIE _EP1_RX[0]_N
GXB_L2 GXB_RX_L6p R2 PCIE _EP1_RX[0_P
GXB_L2 REFCLK2Lp P8 PCIE _EP1_REFCLK_N
GXB_L2 REFCLK2Ln N7 PCIE _EP1_REFCLK_P
EP0
GXB_TX_L1n AD3 PCI_EP0_TX_N[1]
GXB_TX_L1p AD4 PCI_EP0_TX_P[1]
GXB_RX_L1p,GXB_REFCLK_L1p AE2 PCI_EP0_RX_N[1]
GXB_RX_L1n,GXB_REFCLK_L1n AE1 PCI_EP0_RX_P[1]
GXB_TX_L0p AF4 PCI_EP0_TX_P[1]
GXB_TX_L0n AF3 PCI_EP0_TX_N[0]
GXB_RX_L0p,GXB_REFCLK_L0p AG2 PCI_EP0_RX_N[0]
GXB_RX_L0n,GXB_REFCLK_L0n AG1 PCI_EP0_RX_P[0]
REFCLK0Lp W8 PCI_EP0_REFCLK_P
REFCLK0Ln W7 PCI_EP0_REFCLK_N
Error (177035): The input pin PCI_EP0_RX_N[0] assigned to HSSI Pin_AG1 has no fanout.
Error (177035): The input pin PCI_EP0_RX_N[1] assigned to HSSI Pin_AE1 has no fanout.
Error (177035): The input pin PCI_EP1_REFCLK_P assigned to HSSI Pin_N7 has no fanout.
Error (177035): The input pin PCI_EP1_REFCLK_N assigned to HSSI Pin_P8 has no fanout.
Error (177035): The input pin PCI_EP1_RX_P[0] assigned to HSSI Pin_R2 has no fanout.
Error (177035): The input pin PCI_EP1_RX_N[0] assigned to HSSI Pin_R1 has no fanout.
Error (11802): Can't fit design in device. Modify your design to reduce resources, or choose a larger device.
Thanks and Regards
Pavan
